Could someone help me figure out why I am getting such an error. The code below implements a 4 bit shift register adder which takes one bit at a time from each register computes the sum of the 2 bits using a full adder stores the carry (previous) and then pushes the result of the full adder back to first shift register.thus at the end of 4 clock cycles the result (sum) is in the first register
Error i am getting Reg cannot be driven by primitives or continuous assignment.
CODE:
module FADDER(s,c,x,y,z);
input x,y,z;
output s,c;
reg s,c;
always @(x or y or z)
begin
s = (x^y)^z;
c = (x & y) | (y & z) | (z & x);
end
endmodule
module shift_reg_add(a, b,clr, clk);
output [3:0] a,b;
reg [3:0] a,b;
input clr, clk;
reg carr = 1'b0;
wire w1, newcarr;
wire w2,w3;
assign w2 = a[0];
assign w3 = b[0];
FADDER f(w1, newcarr, w2, w3, carr);
always @(posedge clk) begin
a <= {1'b0, a[3:1]};
a[3] <= w1;
b <= {1'b0, b[3:1]};
carr <= newcarr;
end
endmodule
module testbench;
reg [3:0] a,b;
reg clr, clk;
shift_reg_add s1(a,b,clr,clk);
initial begin
clk = 0;
clr = 1;
end
always begin
#2 clk = ~clk;
end
initial $monitor($time, " clr %b a = %b b = %b prev_carr = %b", clr, a, b, s1.carr);
initial begin
a = 4'b0101;
b = 4'b1100;
clr = 1'b1;
end
endmodule
<<---- You declarea
andb
asreg
in your test-bench, but then try to drive them from outputs of yourshift_reg_add
module. As such you will get an error saying areg
cannot be driven via continous assignment. Changea
andb
towire
in your testbench. This would be an answer, but the question is on hold. \$\endgroup\$
