I have the following circuit for which I need to find the time constant:
Would it be correct in assuming that the only relevent resistances are R2 and R4? So then the time constant would simply be (R2||R4)C? Or am I missing something obvious?
Thanks
  • \$\begingroup\$ Assume that the capacitor is charged to a certain voltage. Now imagine it discharging, which components can influence that discharge time? Indeed R1 and R3, R5 cannot influence that. Indeed R2 and R4 can. So yes Tau = (R2||R4) C \$\endgroup\$ Oct 16, 2019 at 7:08
Yes, that's pretty much it.
R1 is irrelevant because it is shorted out by a voltage source, which has zero impedance.
R3||R5 is irrelevant because it is in series with a current source, which has infinite impedance.
The time constant of your circuit can be determined by turning the excitation signal off. If the input is the voltage source, then turn it to 0 V while the current-source is set to 0 A. A 0-V source is replaced by a short circuit while a 0-A current source is simply open-circuited. Then, remove the capacitor and "look" through its connections: what resistance do you "see"?
By inspection, without writing a single line of algebra, you immediately see that the resistance is simply \$R_2||R_4\$ leading to a time constant equal to: \$\tau=(R_2||R_4)C_1\$. As explained with the fast analytical circuits techniques or FACTs, the circuit features a pole located at \$\omega_p=\frac{1}{\tau}=\frac{1}{(R_2||R_4)C_1}\$
