I am working with a few colleagues to build a transceiver system 100% from scratch. A necessary component here is the local oscillator system - we have opted to use a phase shift oscillator to generate our target frequencies. Below is the oscillator circuit we built, modeled through LTSpice:
As I understand, the frequency output should be determined according to the relation: $$f = \frac{1}{2\pi RC\sqrt{2N}}$$ Where N is the number of phase-shift networks and R,C are the values of resistance and capacitance in these networks, respectively.
Based on these assumptions, the above circuit should have N=3, R=10,000, & C=270E-12 - the sinusoidal output is expected to be very near 24KHz. However, both the simulation and actualized circuits are producing a frequency double this, in the vicinity of 47-50KHz. Have I made a poor assumption? Have I overlooked something simple? Why is the actual frequency output double my expected value?
