I'm designing a small battery powered device and I want to use an SSD1327-based OLED display. Unlike the SSD1306, this one doesn't appear to have an integrated boost circuit to power the panel, which wants 8V-18V.
My intention is to power my device with 2 NiMH AAA cells (or 1.5V alkaline) so I will need to boost the ~2.4V up to 3.3V for my controller and ~13V for the OLED panel.
The panel only draws a very small amount of current: ~600uA, and I'm lead to believe that this wouldn't be enough load on a traditional boost converter from an efficiency point of view.
My question:
Given ~2.4V from 2xNiMH AAAs, should I:
design 1 boost converter @ 3.3V and 1 boost converter @ ~12V, both powered directly from the battery, or
design 1 boost converter @ 3.3V (battery powered) and 1 boost converter @ ~12V, this last one powered from the 3.3V generated by the first one, or
design 1 boost converter @ ~12V (battery powered) an 1 linear regulator @ 3.3V, this last one powered from the ~12V generated by the first stage
As far as efficiency requirements go - I'm building a toy, so I only really want lifetime measurable in a handful of hours, not days or weeks.
