I have the following code from one of the files in a project:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
entity twoplayermux1 is
port
--inputs:
show : in std_logic;
set : in std_logic;
input : in std_logic_vector(7 downto 0);
try : in std_logic;
player : in std_logic;
--outputs:
show_out : out std_logic;
set_out : out std_logic;
input_out : out std_logic_vector(7 downto 0);
try_out : out std_logic;
show_out2 : out std_logic;
set_out2 : out std_logic;
input_out2 : out std_logic_vector(7 downto 0);
try_out2 : out std_logic
end twoplayermux1;
architecture Behavioral of twoplayermux1 is
begin
process (show,set,input,try,player)
begin
case(player) is
when "0" =>
show_out <= show;
set_out <= set;
input_out <= input;
try_out <= try;
when "1" =>
show_out2 <= show;
set_out2 <= set;
input_out2 <= input;
try_out2 <= try;
when others =>
null;
end case;
end process twoplayermux1;
end Behavioral;
However, because player
is an std_logic, the compiler gives me the following error:
Error (10515): VHDL type mismatch error at TwoPlayerMux1.vhd(36): std_logic type does not match string literal
The error is in the case statement where I wrote when "0" =>
and when "1" =>
If I change player
to an std_logic_vector of 2 bytes and write when "00" =>
or when "01" =>
then it is being compiled without any errors. However, I do not want a std_logic_vector of 2 bytes. It needs to be 1 byte like so: player : in std_logic_vector(1 to 1);
, but that doesn't work either.
NOTE:
It is a project for an FPGA board.
