Here in USA, we use split phase 240VAC 60Hz. In Philippines, they use single phase 220VAC also 60Hz. How do I make an inverter designed for 240VAC split phase output work properly over there in Philippines for their appliances expecting 220VAC single phase? I believe they use one hot and one neutral but I am not sure. Is there some special way to connect it and/or do I need some special adapter or wiring harness? The outlets there look similar to the NEMA 5-15R used here in USA, except many of them (I think) are tipped sideways and have 3 receptacles instead of the typical 2 vertical ones in USA. They use a combination of both 2 prong (type A) and 3 prong (type B) plugs (even in the same house). Type C plugs are also used but I am not so concerned with those.
Also, a friend of mine who is good with technical stuff told me their stuff will run even better with 240VAC so I might not even have to worry about the 20 "extra" volts. All the appliances might "like" it (run more efficiently). Does anyone have experience with this?
