The EL2602-0010 output terminal has two relays each of which has a single contact. The relay terminal is designed for soft switching at the zero voltage crossing to protect the contacts and is particularly suitable for capacitive loads such as LED lamps. [From the linked catalogue page.]
The manual (thanks, Spehro) seems to indicate that only modules with a single NO contact per channel have the soft-switching feature. Changeover contacts don't. This makes me suspect that there is also a triac switch with zero-crossing capability.
Figure 1. A relay contact with zero-cross triac to give a "soft start".
Figure 2. With zero-cross switching there is no sudden change in current as the turn on and turn off occur at close to zero volts. Source: Opto-triacs, solid-state relays (SSR), zero-cross and how they work.
The idea here is to provide the best features of a triac and the best of a relay contact simultaneously.
- The triac can easily be controlled to switch at zero-cross thus minimising noise on the power lines. Their downside is that due to the voltage drop across them while on they dissipate some power as heat and for long term use heatsinks would be required. The triacs have no moving parts so should last forever if rated correctly.
- The relay contacts are better in that the voltage drop across them is low but arcing during opening and closing wears the contacts and, as they are mechanical devices, millisecond accuracy is difficult so they make poor zero-crossing switches.
- The combination works well because the triac just has to carry the current for a half-cycle or two while the relay contacts close and again when they open. The triac avoids all the normal pain for a relay.
This is all conjecture. If you ever get one then open it up - like a real engineer - and let us know if this answer is correct.
