I have a fuel dispenser, which has one keypad and two displays, each display has three of 7 segment LCDs.
I want to control the fuel dispenser with a PC or a phone. The way to do this in my knowledge is by attaching Raspberry to the fuel dispenser; program the raspberry pi so that it can imitate the same work as the keypad; and read what is written on the display so that I can insert it in a database as a record. Then I can communicate with the pi in different ways.
Now the imitation of the keypad was very easy and I have no problems with it. The problem I am facing is that I am still not able to read what is written on the display.
Let me first show you what does the display looks like:
Display of fuel dispenser
Zomm in of the display
Now the kaypad has 12 buttons ( from 0 to 9, an A button, and F button).
. If I click on A (which means I want to insert maximum amount): the size LCD shows nothing and the amount LCD shows one "0".
. If I click on F (which means I want to insert maximum capacity): the size LCD shows one "0" and the amount LCD shows nothing.
. If I just start pumping fuel with typing nothing, the display starts showing the calculations on the size LCD and its equivalent amount on the amount LCD.
Now data comes from the motherboard, which is sealed to the display through the 10 Pin IDC cable. After measuring each pin of the cable I found:
. 2 Pins of ground
. 2 Pins of 12V
. 1 Pin of 5V
. 2 Pins of 3V
. 3 Pins of -0.3V
So I started to look for which pin sends data. I used Raspberry pi 3B+, and I attached the ground of the raspberry pi to the ground of the cable, and the serial RX of the raspberry pi to each of the other pins (I used 1k Ohms resistor in between).
I found that:
. 2 Pins of 12V and 1 Pin of 5V has nothing
. 1 Pin of 3V sends data each 1 seconds (It also sends data when I click on the keypad)
. 1 Pin of 3V send data each 2 seconds or maybe 3 seconds (when I click on the keypad, it sometimes sends data and sometimes it doesn't)
. The other 3 Pins of -0.3V send only zeros (Even if I click on the keypad)
Now the problem is that I don't understand the data that I receive from the raspberry pi. I just see it as random numbers.
Here is what I see from one Pin of 3V: First Pin of 3V
This is from the other 3V Pin: enter image description here
It even changes it value other than 165 sometimes.
This is the python code I am using on Raspberry pi:
import serial
ser = serial.Serial("/dev/ttyS0", baudrate=9600, bytesize=8, timeout=1)
try:
      while 1:
            response = ser.read()
            if response:
                  print response
                  print ord(response)
                  print bin(ord(response))[2:]
                  print "---------------------"
            #line = ser.readline()
            #if line:
            #     print line
except KeyboardInterrupt:
      ser.close()
I tried changing baudrate and bytesize, and received the same random numbers.
Here you can find the datasheet of the "PCF8576CT" LCD driver:
https://www.nxp.com/docs/en/data-sheet/PCF8576C.pdf
I apologize for making this long, and I hope you can find solution to this.
Thank you
    \$\begingroup\$ The LCD controllers have I2C bus. What suggested you to try receiving data with UART? Is there a microcontroller onboard? \$\endgroup\$
    – Justme
    Commented Dec 28, 2019 at 18:03
  • \$\begingroup\$ that appears to be the display for a fuel dispenser, not the control unit \$\endgroup\$
    – jsotola
    Commented Dec 28, 2019 at 20:56
  • \$\begingroup\$ @Justme Thank you for your reply. Since I found that voltage wasn't the same in all pins, I directly suggested that data is transmitted in serial. Then I searched for how to read serial data using Raspberry pi, and I found this way. I didn't know that there is difference between I2C and UART. This is really good information. \$\endgroup\$ Commented Dec 28, 2019 at 21:47
  • \$\begingroup\$ @jsotola Yes, and I didn't check if there is any microcontroller behind the display board. I thought there shouldn't be a microcontroller since these LCD drivers can receive data directly from the control unit. \$\endgroup\$ Commented Dec 28, 2019 at 21:53
  • \$\begingroup\$ @GaijinForce, you said that you want to control the fuel dispenser with a PC .... controlling the display will probably not achieve that goal \$\endgroup\$
    – jsotola
    Commented Dec 28, 2019 at 22:02
The protocol used for the communication with the LCD controller chips is I2C. It can't be received with an UART like you are now trying. You would need a special I2C logger tool or logic analyser to analyze it. Fortunately the RPi has I2C master interface so you could use it for talking to the LCD controller chips. Even an oscilloscope would help you to look at the waveforms, but if you can trace the I2C interface pins and understand the LCD controller datasheet how to initialize and use it, it might work, but many initialization parameters depend on what type of LCD it is and how it is connected to the driver chip.
  • \$\begingroup\$ Yes I was already worried about if I receive data as bits of each segment on the display. However, I think it's only a matter of time to understand what each bit refers to. I only want data to be stable, and not just random. \$\endgroup\$ Commented Dec 28, 2019 at 22:19
