I'm trying to add a DC offset level to a sine signal through an instrumentation amplifier (as the figure below shows.)
The problem is that, in the simulation, everything works perfectly, however, in reality I can't achieve the DC displacement of the signal. The input signal parameters are: 0.7Vpp and 100Hz
The image shows the wanted behavior of the circuit, however, I'm not able to obtain that in real life.
What could be the problem? Maybe the AD620 is not the best option to do that?
