I am trying to create an updated version of a mems mic board, like this one from sparkfun. They use an INMP401 mems mic (which is not recommended for new designs) and an OPA344 for the preamp stage (20 years old, from the datasheet creation date).
My objective is to improve it a bit in terms of a wider frequency response, better noise tolerance, low power, etc. using a different mic and a different opamp. By "different" I mean more recent.
I have been checking some application notes on the topic, like this one from AnalogDevices and this one from ST.
In the end, I have some parts that I am comparing but couldn't decide which one to select. The only feature for the OPA344 that is better than the others is its low power consumption, but for Slew Rate, Noise, THD, and Bandwidth, all are better than it. Here is the comparison table: (green boxes are what I think are pros of each part).
Is there any tip about which additional feature I should look at when designing a preamp stage? Any suggestions from the previous list? In case low power is not a requirement, which opamp could be selected instead?
Thanks.
