I am working on a project which needs a Schmitt trigger. I designed it using IC UA741. I am using a single power supply of 9V. I am grounding the V-.
Here is my design.
The circuit works perfectly in this software as well as other software.
When I do the same in hardware it is not working. I was even getting 2V at V- pin i.e 4 pin. Even though I had grounded it. And the output voltage is always 5.67 V at pin 6.
Can Anyone help me and highlight my fault?
Thank you
Edit... This is my new circuit. Is there any visible erors here? I haven't tried it on hardware yet. enter image description here
Thank you
    \$\begingroup\$ If you have grounded pin 4, but measure 2 volts there, it is not grounded - check your wiring. The schematic shows the LED the wrong way up. \$\endgroup\$ Commented Feb 4, 2020 at 2:44
  • \$\begingroup\$ Led is fine....It's was just for testing.... \$\endgroup\$ Commented Feb 4, 2020 at 2:49
  • \$\begingroup\$ I will test the wiring.Thank you \$\endgroup\$ Commented Feb 4, 2020 at 2:50
    \$\begingroup\$ The voltage levels you are using will not work with a 741 (or even an LM358). You need to pay attention to details such as the common mode range of the opamp. \$\endgroup\$ Commented Feb 4, 2020 at 3:13
  • \$\begingroup\$ Look down the list of reasons not to use a 741 and you will see at least one reason right at the top. \$\endgroup\$
    Commented Feb 4, 2020 at 8:11
Few thoughts. Check your connection to ground as peter Bennett mentioned.
Second Issue is that your op-amp cant run close to the ground rail as Kevin White mentioned. Look up common mode input range. Your input is running at 1.8 V where as you can only go down to about 3V on the inputs according to the data sheet assuming a +-15v supply it can go +- 12 (VICR "Common mode input range"). It will behave similarly at 9 Volts. This effectively leaves your operating area on the inputs between 3V and 6V on this op-amp. Where as you are running the op-amp at 1.8 volts on the input.
If this is the problem, the solution would be to find an op-amp that can go down to 1.8 volts and lower on the inputs or to change your dividers. Where 8k and 2k resistors changed to 5k on the Vin-. And the 10K going to 1k and 5k going to 9k on Vin+. This would let the operating voltage of the input be 4.5 with an output of 5V.
  • \$\begingroup\$ Thanks I didn't knew about common input range.I will try it in hardware then. \$\endgroup\$ Commented Feb 4, 2020 at 12:03
  • \$\begingroup\$ yes it is an annoying factor to consider. I would recommend getting a different op-amp that runs closer to the rails as you are using 9 volts which is much different from the +- 15 volts this was designed for. \$\endgroup\$ Commented Feb 4, 2020 at 21:25
