I'm want to digitize an +/- 2.5 V signal using an ADS1256. Since the IC can't take negative voltages I designed a level shifter with a LM324 to translate the +/-2.5 V signal to 0 - 5 V but I was only able to translate up to 3.4 V since the LM324 isn't rail-to-rail. I also realized that the input signal (+/-2.5V) and output signal (0-3V) have different phases. I would like to know if I'm losing resolution or accuracy reading designing the level shifter with a LM324 instead of a rail-to-rail Op-Amp. The frequency range of the signal is 1 to 10 Hz.
The circuit I used is from this website: https://vidnyankendra.org/2017/02/17/level-shifter-using-op-amp/
