I have the following problem.
Consider the circuit below, where the bottom of the arrow is the +-pole of the voltage drop:
What resistor value for \$R_2\$ gives a damping factor of \$d=0.9\$ for the filter transfer function \$\frac{V_{out}}{V_{in}}\$.
Okay so first thought is to find the transfer function. We can write a node equation for \$V_{out}\$.
\$ \frac{V_{out}}{R_2}+\frac{V_{out}}{600 \Omega}+\frac{V_{out}}{330 \text{nF}}+\frac{V_{out}-V_{in} }{5.1 \text{uH}} =0\$
Rearranging this equation with Maple gives me following transfer function.
\$ \frac{V_{out}}{V_{in}}=\frac{196080 \cdot R_2}{1+3.22638\cdot 10^6 \cdot R_2}\$
But from here I'm kind of stuck, since I don't know where to go. However, I have these equations from my notes that might help me.
\$ d=\frac{1}{Q_{factor}} \$
\$ B_{bandwidth}=\frac{f_c}{Q_{factor}} \$
Where \$ f_c\$ is the resonance frequency.
I hope someone can help me with this.
