let's consider this NMOS common source voltage amplifier with active load:
For small signals the PMOS transistor M2 acts as a resistor of value \$\frac1{g_{mP}}\$ (P stands for PMOS) and so the voltage gain of this amplifier will be:
G = \$-\frac{g_{mN}}{g_{mP}}\$
I have been told that in some IC it is not a good amplifier because it has a big sensitivity to temperature variations, since \$g_{mN}\$ and \$g_{mP}\$ change differently with temperature and so their variations are not balanced. It would be a better option to get a gain which are expressed as ratios of similar physical quantities.
So my question is: why not use always a NMOS transistor as active load? Something like this:
I'd say it will work exactly in the same manner. But I have always (or almost always) seen the amplifier with a pmos active load. Also in differential pairs, I have always seen only pmos active load for nmos amplifiers:
