Suppose we have a 2d Systemverilog array declared as:
logic x [0:3][7:0] ;
  1. How can we use an attribute to get the width of the first dimension ?
  2. How can we use an attribute to get the width of the second dimension ?
  3. Is there an attribute equivalent to VHDL's "range" attribute ? I.E: one that'll return not the size but the actual range ( 0 to 3 ) or ( 7 down to 0 ) ?
The IEEE Std 1800-2017, section 20.7 Array query functions, describes all that you need:
module tb;
initial begin
    for (int i=1; i<=$dimensions(x); i++) begin
        $display;
        $display($size (x, i));
        $display($left (x, i));
        $display($right(x, i));
        $display($low  (x, i));
        $display($high (x, i));
        $display;
    end
end
endmodule
Outputs:
      7
See also System Tasks And Functions Part-II
  • \$\begingroup\$ Is IEEE Std 1800-2017 freely available ? If yes, where can it be download ? \$\endgroup\$
    – shaiko
    Commented May 30, 2020 at 21:09
    \$\begingroup\$ @shaiko Click on the IEEE Get Program \$\endgroup\$
    – dave_59
    Commented May 31, 2020 at 3:57
