schematic and input waveform
I'm asked to determine the active power (P). (I don't know if that is actually called active power in English?)
The formula of P is = U * I * sin(alpha)
How can we determine the alpha in this case, so that we can calculate the P?
    \$\begingroup\$ It's called "active" or "real" power in English, indeed! However, your two diagrams seem to have nothing to do which other (and if I was grading the right plot: no points, since the description what this actually depicts is missing). However, assuming something in your system is not a sinusoidal signal, there's no single "phase" alpha that you could just plug into your formula – it doesn't apply here. \$\endgroup\$ Commented Jun 20, 2020 at 11:45
Well, we have the following circuit:
The input voltage is given in the following diagram:
Assuming an ideal diode, the negative parts are cut of for the voltage across the resistor. That is shown in the following diagram:
Now, we know that the power in a resistor is given by:
$$\text{P}_\text{R}\left(t\right)=\frac{\text{V}_\text{R}^2\left(t\right)}{\text{R}}\tag1$$
It is not hard to show that \$\text{V}_\text{R}\left(t\right)\$, is given by:
$$\text{V}_\text{R}\left(t\right)=\frac{\text{V}}{\text{T}}\sum_{\text{n}\ge0}\theta\left(t-\text{Tn}\right)\mathcal{I}_\text{n}\left(t,\text{T}\right)\tag2$$
Where:
$$\mathcal{I}_\text{n}\left(t,\text{T}\right)=\left(\text{T}\left(1+2\text{n}\right)-2t\right)\left(\theta\left(t-\text{T}\left(\frac{1}{2}+\text{n}\right)\right)+\theta\left(t-\text{T}\left(1+\text{n}\right)\right)\right)\tag3$$
Now, we can look at the average power and the RMS power using the following two formulas:
  • Average power: $$\overline{\text{P}}_{\text{R}}=\frac{1}{\text{T}}\int_0^\text{T}\text{P}_\text{R}\left(t\right)\space\text{d}t\tag4$$
  • RMS-power: $$\text{P}_{\text{R}|\text{RMS}}=\sqrt{\frac{1}{\text{T}}\int_0^\text{T}\text{P}_\text{R}^2\left(t\right)\space\text{d}t}\tag5$$
I used Mathematica to find them:
Average power:
In[1]:=Integrate[(1/
    T)*(((Sum[(V/
           T)*((HeavisideTheta[
             t - T*n])*(((-2 t + T +
               2 n T) (-HeavisideTheta[t - T/2 - n T] +
               HeavisideTheta[t - (1 + n) T]))/1)), {n, 0,
         Infinity}])^2)/R), {t, 0, T}, Assumptions -> T > 0]
Out[1]=V^2/(6 R)
RMS-power:
In[2]:=FullSimplify[
 Sqrt[(1/T)*
   Integrate[((((Sum[(V/
             Infinity}])^2)/R))^2, {t, 0, T}, Assumptions -> T > 0]],
 Assumptions -> V > 0 && R > 0]
Out[2]=V^2/(Sqrt[10] R)
  • \$\begingroup\$ I can't do much about isolated downvoting, the only thing that I can do is vote myself, but that is something that the community can do, so if you see bad votes make sure you also cast a vote ( which the only one that has is me attm) \$\endgroup\$
    – Voltage Spike
    Commented Jun 20, 2020 at 22:48
  • \$\begingroup\$ No such meaningful quantity as RMS power. \$\endgroup\$
    Commented Jun 20, 2020 at 23:35
You'll notice that your circuit is nonlinear, due to the diode. Hence, if you want to know powers, you'll have to integrate the squared product of current and voltage over a period and then divide the thus calculated energy by the length of the period.
You seem to have a description of the voltage over time (although that graph isn't sufficiently labeled, so we don't know what we're looking at exactly; this might be the voltage over the diode, over the resistor, or over the voltage source), but you don't have a description of the current. You need to first find that definition of the current over time!
That might be very easy, or relatively complex, depending on how you model that diode. But it's something we can't do for you.
The rest should just be solving an integral. That's doable.
And
Not in this universe. That formula is for "so-called" reactive power but, you don't have any reactive components so it's null and void.
The RMS of a triangle or saw-tooth waveform is this: -
So, without the diode half wave rectifier, the power is: -
$$\dfrac{\left[\dfrac{V_P}{\sqrt3}\right]^2}{R}$$
But, because of the rectifier, only half of that power reaches the load: -
$$\dfrac{\left[\dfrac{V_P}{\sqrt3}\right]^2}{2\cdot R}$$
I'll leave you to plug in the numbers.
