I am using the Analog Devices ADXL343 accelerometer (https://www.analog.com/media/en/technical-documentation/data-sheets/ADXL343.pdf) which advises using a 1uF tantalium cap on one power line, and a 0.1uF ceramic on the other. I can't see any reason to prefer tantalium - ceramics of that size are easily available in my preferred 0402 chip size, and a fraction of the cost. Am I missing something? On Digikey tantalium cap one-off is about £1.50 but ceramic just 8 pence!
\$\begingroup\$ from the datasheet (which you could have linked for a better question and to attract good answers), they suggest either 1 or 10µF. while small form factor of ceramic 1µF exist, im not so sure about 10µF. Also, the technology is only a suggestion. You have to think about desirable qualities for decoupling capacitors, and how tantalum and ceramic measure up against those expectations \$\endgroup\$– SclrxCommented Jul 9, 2020 at 7:05
\$\begingroup\$ Thank you! Link added. I have to admit I don't really understand how difference between the two will affect how the decoupling works. I have read a few things on the web but tends to talk about stability of capacitance with temperature/voltage which doesn't really affect me. Question probably is exactly that - how does tantalium vs ceramic affect desirable qualities for decoupling capacitors? \$\endgroup\$– bgarroodCommented Jul 9, 2020 at 7:45
\$\begingroup\$ "Below 10 kHz the ESR of ceramic capacitors increases, so tantalum or aluminium electrolytic capacitors are recommended in this frequency range" That possibly explains tantalum for Vs. dataweek.co.za/news.aspx?pklnewsid=27008 \$\endgroup\$– P2000Commented Jul 10, 2020 at 6:34
1 Answer
It should be fine.
The choice of decoupling capacitors is one of those matters that can either solved with "slap 0.1µF on that" or weeks of analysis.
what you want is a big reserve of charges to allow your chip to pull current without dropping the supply voltage, and a small but low ESR (equivalent serie resistance) cap to shunt the high frequencies that could come from it.
As a rule of thumb, 1µF + 0.1µF, both in ceramic, should be fine for the most common applications, including yours. I recommend reading up on the subject, it has helped me drastically as a designer. This answer and this application note are good starting points.
