I have a high current low voltage MOSFET I'd like to drive with a higher voltage and a micro to reduce power losses through it. I built this circuit based off the typical level shifting designs. The MOSFET does not turn off. The circuit has been reconstructed twice, and both times the MOSFET works fine before and after, so I don't think I'm breaking anything. Any ideas as to why its not working?
I am a bit new to circuits, so please correct me if I've made some very silly mistake.
edit: source and drain of the 2N7000 should not be connected together like they are in the picture, not sure what happened there - source should connect to the logic signal, drain should connect to the power mosfet
