The single most important thing I miss in LTspice is the ability to plot things of multiple runs on top of each other. Cadence Virtuoso calls that "Append Plot".
What I mean: I want to plot one node of my circuit, hit "Run" and plot. Then change the topology and run again and plot the result on top of the first one. This makes it easy to see the impact of multiple blocks/parsitics/changes directly in the waveform.
I know I can export the plot after each run and plot them on top in MATLAB for example. I also know I can use .step
. But this does not (easily) allow for topology changes. None of these two are solutions.
.step
would have been the solution, without external intervention. Cadence must have a behind-the-scenes merge utility that appends the results of the simulation, or, at the very least, involve some sort of temporary save. Alas. Otherwise, if you do intend to go the.step
way, maybe this can be of a help. \$\endgroup\$
