I'm designing a PCB that will control AC 240V electric tools. For now I decided to use a single double pole relay to switch live and neutral lines.
Is it also safe to use two separate single pole relays (one for each lines) that would be controlled by the same signal at the same time ?
2 relays would be cheaper than a double pole one.
I'm asking this question cause I'm thinking of the case where one relay would break and only one would remain good.
