I was looking at the datasheet for the LTC-4627JR, and it looks like each digit shares a common anode, and each segment shares a common cathode.
My question is given this configuration, I don't understand how to drive each digit separately.
For example, say I want digit 1, segment A
and digit 2, segment B
to be on, with everything else off.
I could attach pin 1
and pin 2
to Vcc to enable the two digits, but if I try to connect pin 14
to ground (through a resistor, of course), this will turn segment A on for both digit 1 and digit 2. Likewise, trying to connect pin 16
to ground, this will turn segment B on for both digits.
Is there something I'm missing here? Or is this how this display is intended to work?
This is similar to this question, but as far as I can tell the answers to that question doesn't allow powering all digits differently from each other.
