I'm new to electronics, and learning as I go. I need help on a circuit that otherwise works great. This is a magnetic power on-off switch, I'm using a relay switch to supply LIPO BAT power to a regulator. When turned on, the line to regulator measures full BAT power as expected, but when the switch is turned off, the line to the regulator is still measuring around 0.76 V, and slowly drains the battery over time. How can I eliminate or reduce drain to the battery when off?
Update: My mistake on this, I didn't show the full circuit, there was a resistor down the line causing a problem.
