One of these connectors is the type that plugs into my receiver's FM antenna input, and the other is an aftermarket FM antenna output connector. I think the one with threads is called "type F" but my searches are coming up with a lot of garbage, hence I'm not sure. The other one I'm not getting even a poor answer.
Is this ANT-108? I have my doubts. The back of the receiver is, of course, the mating connector, and that's what I really need to join up with, not this thing. But I can't easily get a picture of the back of the receiver, sorry.
I want to join the bottom (type F) connector to the mate of the top connector. Should I consider getting the mates to these two connectors and hacking up my own bit of wire between the two cables? Or can you tell that this aftermarket antenna just isn't supposed to be connected to this kind of receiver?
