I've wire up ATMEGA64A-AU based on this schematic from here:
I've tried to program a blink on pin B5 which has a LED on it:
#define F_CPU 16000000UL
#include <inttypes.h>
#include <avr/interrupt.h>
#include <avr/io.h>
#include <util/delay.h>
#include <stdlib.h>
void main( void )
DDRB |= (1 << PB5);
PORTB |= (1 << PB5);
while (1){
_delay_ms(1000);
PORTB ^= (1 << PB5);
It works actually fine. But when I tried to enable USART on the chip by adding these:
#define FOSC 1843200 // Clock Speed
#define BAUD 9600
#define MYUBRR FOSC/16/BAUD-1
void USART_Init( unsigned int ubrr )
UBRR0H = (unsigned char) (ubrr >> 8);
UBRR0L = (unsigned char) ubrr;
UCSR0B = (1 << RXEN0) | (1 << TXEN0) | (1 << RXCIE0);
// Set frame format: 8data, 1stop bit
UCSR0C = (1 << USBS0) | (3 << UCSZ00);
It still work. But when I add this code to main function:
USART_Init(MYUBRR);
Toggling stops!
Why does this happen? I couldn't found any thing on its datasheet. PB5 hasn't any thing to do with USART to my understanding.
PS:
This chip has some weird property like this but it comes with two UARTs and it is cheaper than the others! That is why I choose it.
Update 1:
ATMEGA64A has two fuse bit which was new to me :
- ATmega103 compatibility mode fuse which was set as default and shouldn't be in my case.
- JTAG fuse which I don't have a device to use it! I use ISP programmer, so it shouldn't be set.
It starts blinking after setting them, but still I don't understand how they got PB5 involve, they use other pins!
