I've been asked by a friend to make such a recommendation, to go along with his new Weller WES51. I've told him:
- 60/40 tin/lead
- rosin-core
- good name brand, such as Kester
What's a good size to recommend for general purpose use?
Here's your standard size list.
For general-purpose electronic tinkering/prototyping, I recommend 26-28 awg sized no-clean rosin cored tin/lead solder (63%/37%).
In Kester terminology it's this one:
SN6324550.015
63/37, 245 FLUX, 50 CORE, .015 DIA, 1 LB
For small components, pretty much any of the standard sizes will work. In general, you should size the solder with the components. The smaller the components, the smaller the radius of solder (especially if doing SMD use very thin solder). For cases where you're soldering to large amounts of metal, it's best to use larger solder and more powerful soldering iron or it will take too long.
A general recommendation is Kester 0.010" solder for SMD, and Kester 0.025" for through hole.
I use 0.5mm diameter for normal stuff and 0.35mm for SMD work.
Though 1mm would also be OK for through hole, and you would need much less length for the same amount of solder.
