I need to generate a square wave / clock with configurable frequency between say 60 to 500Hz. There are not stringent requirements on the frequency stability. I need to be able to modulate this frequency at run time periodically (say once every few seconds) using an external uC using either GPIO or I2C. I have looked at programmable oscillators and programmable alarm ICs and have yet to find any that can do what I want. I am OK with having a roll your own type of circuit for this as long as it's not super complicated.
The purpose of this is to provide timing control to some external power FETs which will switch a regulated DC voltage on and off. I don't want this switching to be halted if the software running on the uC dies for some reason. So I want an external IC to control the switching.
Can you recommend a circuit that can meet my needs?
