I want to design a SDI-12 interface and I am using this schematic as a starting point. In receive mode, the 5V SDI-12 data signal will reach UART RX via the transistor Q1, but will also reach the output of the buffer U1 (I my case, it is a 74LV1T126GVH).
So, is there a risk of damaging the buffer when applying the RX voltage on its output? If so, what solution is there to this problem?
  • \$\begingroup\$ Paste the schematic into your question but leave the link for reference. \$\endgroup\$
    Commented Nov 4, 2020 at 12:25
  • \$\begingroup\$ @Andyaka I've included the schematic. \$\endgroup\$
    – Cristian M
    Commented Nov 4, 2020 at 12:29
  • \$\begingroup\$ Have you read the buffer datasheet if it allows it or not? \$\endgroup\$
    – Justme
    Commented Nov 4, 2020 at 12:37
  • \$\begingroup\$ Is the buffer active (OE low) usually ? Is it during this time that is your concern ? Have you added the 510R resistors yourself ? Is there a reason why you couldn't clamp the voltage to say < Vcc instead of the 7.5V ? \$\endgroup\$
    – citizen
    Commented Nov 4, 2020 at 12:48
  • \$\begingroup\$ @Justme The datasheet does not specify anything about applying voltage to its output. It only refers to inputs. \$\endgroup\$
    – Cristian M
    Commented Nov 4, 2020 at 12:55
The buffer will not work. And the schematic violates some of SDI-12 tranceiver requirements, such as DC impedance to GND.
The buffer will also not tolerate 5V on output if it is unpowered (VCC=0), so it will load down the bus outside the allowed limits of SDI-12 specs.
It needs an inverting buffer like in the example schematics, unless the UART_TX polarity can be set in the MCU. Sometimes UART polarity can be set, but is it separate for TX and RX is another question. As it is now, UART_TX and UART_RX will have opposite polarity, as the FET inverts the data.
Otherwise the schematic is almost a copy of reference design from SDI-12 standard.
  • \$\begingroup\$ Yes, you are right and thanks for noticing these issues. This schematic is a starting point; the 200k resistor and 3.3nF capacitor to ground are missing and I will add them. The buffer will not be powered off, so there will not be any issues regarding the tolerance to 5V. I missed the fact that SDI-12 uses a negative logic; however, I can't use that buffer (SN74LVC1G240) because it does not accept 3.3V signals when powered at 5V. I will invert UART TX with the inverting buffer 74LV1T04. Now, the TX and RX polarity should be fine on both sides (MCU and SDI-12). Please tell if you agree. \$\endgroup\$
    – Cristian M
    Commented Nov 5, 2020 at 18:05
  • \$\begingroup\$ I don't see the point of using two chips for this. If you go to chip manufacturer or distributor websites and do a parametric search for TTL compatible inverting three state buffers that work at 5V supply, I'm sure you find a suitable part. Maybe the MCU supports 5V levels so simply a pull-up to 5V is enough? \$\endgroup\$
    – Justme
    Commented Nov 5, 2020 at 18:32
  • \$\begingroup\$ The host is a I2C-UART bridge (MAX14830) and does not support 5V levels. Basically I need a 3-state inverting buffer with non-inverted enable input (active high OE), because it is controlled by !UART_RTS (which is not under my manual control). I've search several chip manufacturers' websites, but did not find a chip that meets these requirements. \$\endgroup\$
    – Cristian M
    Commented Nov 5, 2020 at 18:40
What you need is Tri-state buffers.
When one output or one input is not in use, it can be set as high impedance with the EN or -OE pins. And so the input or output is protected up to Vcc or even sometimes above that.
