I want to know what is different between voltage reference and virtual ground and can you use both of it as rail-splitter in transimpedance amplifier, if not why.
All I know is Virtual ground chips like TL2426 have an opamp buffer at the output, but the main issue if supply voltage changes the output change too due to voltage divider.
Below part number is connect just for demonstration(actual opamp pn is mcp6v02)
