I am new to electronics (using Arduino), begging to venture into creating my own circuits and not following set example. I would appreciate advice on the following.
When deciding upon how to power a circuit how exactly does one go about this? For example, I'm planning on using my Arduino Uno to control six MG996R servos via six potentiometers. For my understanding each:
- MG996R servo requires: 5 - 6 V and 1.3 - 2.5 amps (stall to 6 V load working).
- Arduino Uno: 5-7 V input and 40 mA per pin output // 5 V input being sufficient as I do not plan on using 5 V output.
- Potentiometer: no specific / negligible volt/amp draw
Thus, to power the above I would require a power source of max 6 V (within operating limit of servo and sufficient for Arduino, and a total amp of:
- 15A (6 x 2.5 amp for all six servos)
- 240mA (6 x 6 pinouts on Arduino required to control PWM on servos). Total: 15.24 A
So overall for above I need a power supply: 6V, 15A. Is this correct?
If so, then my next question comes in how to power this from a battery? All the LiPo's (3S) I've used for drone etc thus far are 11.1V and 1500 - 3000 mA // way below the amps needed for above. Also I've always used a power distribution board to provide 5V to the Arduino, which provide only 2 - 3A.
I do have a external variable power supply but I'm reluctant to have 15A running as this seems considerably higher than anything I've used before and I don't trust my working. Also, I can't find a maximum amp limit for the Arduino, but feel that 15A would exceed its working limits.
I'm confused. Either I've got the workings completely wrong or I'm stuck at how to provide sufficient power to six servos using a battery, and not frying my Arduino at the same time.
