I'm working on making a switch that can be turned on with a microcontroller.
I have it mostly wired on a protoboard, and it kind of works, except that even when the relay coil isn't energized and the relay is open, there is a little bit of current still flowing.
The relay I'm using is a PCJ-112D3M.
I hooked the black multimeter wire to the neutral AC wire, and the red multimeter wire to the hot AC wire after it goes through the relay. When the coil is energized the meter reads 120VAC as expected. But when the coil power is turned off, the meter reads 40VAC.
I'm not sure if it's just a bad relay, or if this is somehow expected behavior, but it doesn't seem right.
I just wanted to double check before I desolder the relay and replace it with a different one.
