I was trying to amplify the signal of a piezo, which is very low and amplify it so that I could use it to latch a flipflop. I had the LM358 opamp so I made a differential amplifier by a gain of 50 so that the output would reach 5 volts which is a high logic level.
I got the design of it from internet, I just changed the gain. I was measuring the output with my multimeter (I do not own an osciloscope,) but the output was never what was expected. The maximum voltage I measured was 1volt, but it should have been 5volts.
No matter what I tried, the output was same. I do not know if the opamp is not working or if I am measuring wrong.
Please tell me what am I doing wrong or what the problem is.
