I have an MSP430FR6989 development board (MSP-EXP430FR6989).
I would like to program it to communicate with a MAX30102 Pulse Oximeter and Heart Rate IC, the interface is done through I2C protocol.
I have only one master (MSP430) and one slave (MAX30102).
From reading the MSP430 user guide (pg821 Chapter 32 eUSCI I2C Mode) and the MAX30102 datasheet (pg16/32), this is my understanding:
- we write slave address in master address register
UCB0I2CSA = 0x57
, setUCTR
for a write, and setUCTXSTT
for a START condition. - MSP430 transmits the slave's address along with the write bit, (8 bits toggled from the SCL)
- MAX30102 sends an ACK signal (LOW), the
UCTXSTT
bit is cleared, and theUCB0TXIFG0
bit is set - when
UCB0TXIFG0
bit is set, MSP430 goes to an ISR, interrupt flag gets cleared, and we write the address register of MAX30102 FIFO_WR_PTR into the Transmit BufferUCB0TXBUF
. - MSP430 transmits the data (FIFO_WR_PTR register address) and waits for an ACK from the MAX30102.
- When an ACK is received (second ACK),
UCBOTXIFG0
bit is set, goes to the ISR, we clear theUCTR
bit for a read mode and setUCTXSTT
for a REPEATED START condition. - The slave address remains the same and gets transmitted to the slave along with the read bit.
- Slave acknowledges it (ACK), and the
UCRXIFG0
is set, MSP430 goes to eUSCI_B0 ISR (this time, value at interrupt vector corresponds to Received Data). - at ISR value at
UCB0RXBUF
(FIFO_WR_PTR) is stored in a global variableWritePointer = UCB0RXBUF
I have written an MSP430 code accordingly.
#include <msp430.h>
#include <stdint.h>
uint8_t WritePointer = 0;//to store the value inside the FIFO_WR_PTR
#define ENABLE_PINS 0xFFFE
#define MAX30102_SLAVE_ADDR 0x57
#define MAX30102_FIFO_WR_PTR_ADDR 0x04
//other address definitions
// S SLA/W (A) FIFO_WR_PTR_ADDR (A) SR SLA/R (A) (FIFO_WR_PTR) NACK P 1st interaction
* Private Variables
void configClock(void);
int main(void)
WDTCTL = WDTPW | WDTHOLD; // stop watchdog timer
PM5CTL0 = ENABLE_PINS;
configClock ();
//config pins P1.6 SDA P1.7 SCL
P1SEL0 &= ~(BIT6 | BIT7);
P1SEL1 |= (BIT6 | BIT7);
UCB0CTLW0 |= UCSWRST;//put it on a restart mode to config
UCB0CTLW0 |= (UCMST | UCMODE_3 | UCSSEL__SMCLK);// i2c master cs smclk
UCB0BRW = 10;//100kbps fSCL = fSMCLK / 10 = 100 KHz
UCB0IFG &= ~UCTXIFG0;//set eUSCI_B0 for operation
UCB0I2CSA = MAX30102_SLAVE_ADDR;//from datasheet address is 0x57
UCB0CTLW0 &= ~UCSWRST;//release for operation
UCB0IE |= (UCTXIE0 | UCRXIE0);//enable RX and TX isr
//when and ACK is received a tx or rx isr is serviced
_BIS_SR (GIE);//enable global interrupt
while(1)
UCB0CTLW0 |= (UCTR | UCTXSTT);//W and START
return 0;
void configClock (void)
CSCTL0 = CSKEY;
CSCTL1 = 0x0000;//DCO 1MHz
CSCTL2 |= (SELA__LFXTCLK | SELS__DCOCLK | SELM__DCOCLK);
#pragma vector = USCI_B0_VECTOR
__interrupt void eUSCI_B0_I2C_ISR (void)
static int counter = 0;
//this is a byte counter, after the Slave ACK Address and W
//Master is expected to transmit data (register address of FIFO_WR_PTR)
//then set a REPEATED START, along with the slave address (the same) and change the mode to read
switch(UCB0IV)
case USCI_I2C_UCTXIFG0:
if(counter == 0)
UCB0TXBUF = MAX30102_FIFO_WR_PTR_ADDR;
counter++;
else
UCB0CTLW0 &= ~UCTR;//R
UCB0CTLW0 |= UCTXSTT;//repeated start
counter = 0;
break;
case USCI_I2C_UCRXIFG0:
WritePointer = UCB0RXBUF;
//WritePointer is a global variable
//FIFO_WR_PTR is assigned to WritePointer
UCB0CTLW0 |= UCTXSTP;
//MSP430 to initiate STOP condition
break;
default:
break;
However when I build and to run the code, I probed the SCL (P1.7) with an oscilloscope and I only get a high voltage (3.3V). Even if my I2C software configuration is wrong, I should still get at least 9 pulses (7 bits address, 1 bit Write, 1 bit ACK/NACK) from the SCL with the oscilloscope.
When I debugged the code and the MSP430 goes inside the while loop, when UCTXSTT
is set, no interrupt flag is set.
PS: the HW connection is an open drain, with 4.7K ohm resistors acting as pullup resistors.
I don't know where is my error, kindly help me with this issue.
