I'm trying to configure and read two ADCs (MAX11156) with a RaspberryPi. The ADCs are daisy-chained together. For the communication, I'm using python code with the spidev library. The driver is properly installed and SPI0 is enabled. However, the received data doesn't make sense to me at all and I'm trying to figure out, whether it's a software or a hardware issue.
The data I have received, resembles what I measured with an oscilloscope. Having nothing connected to the analog input, I receive following raw bytes for a period of 10 samples:
[63, 255, 0, 0, 0] decoded: -2.0481V -4.0960V
[192, 1, 63, 255, 255] decoded: 2.0481V 4.0960V
[192, 0, 31, 255, 255] decoded: 2.0480V -0.0000V
[63, 255, 32, 0, 0] decoded: -2.0481V 0.0000V
[63, 253, 224, 0, 0] decoded: -2.0483V 0.0000V
[63, 254, 0, 0, 0] decoded: -2.0482V -4.0960V
[192, 3, 223, 255, 255] decoded: 2.0485V -0.0000V
[192, 3, 31, 255, 255] decoded: 2.0484V -0.0000V
For the configuration, I'm sending two times the same configuration byte (1,0,0,0,0,0,0,0).
After configuration I give the ADCs some time to convert. To read the data, I'm transferring 5 bytes of 255 (since the register is expecting a logic high during transmission). I'm expecting 5 bytes, since the ADCs have a 18bit resolution, so 36 bits in total. The last 4 bits are ignored.
This is my code:
import time
import spidev
def configuration(b7,b6,b5,b4,b3,b2,b1,b0):
msg = (b7 << 1) + b6 #first 2 bits: 10 - MODE: Daisy-Chain Mode, no busy indicator
msg = (msg << 1) + b5
msg = (msg << 1) + b4 #next 2 bits: 01 - REF: Reference Mode 1
msg = (msg << 1) + b3
msg = (msg << 1) + b2 #next bit: 0 - SHDN: Normal Mode
msg = (msg << 1) + b1 #next 3 bits: 000 - Reserved
msg = (msg << 1) + b0
return msg
def decodeDaisyChain(ans):
#accepting list of 5 bytes for two 18 bit in a range of +-5V chained together
val1 = ((((ans[0] << 8) + ans[1]) << 8) + ans[2]) >> 6
val2 = (((((ans[2] & 0b00111111) << 8) + ans[3]) << 8) + ans[4]) >> 4
val = ([val1,val2])
# convert to voltage (-5,+5V)
Vref = 4.096
step = Vref*2 / 2 ** 18 # in Volts
zero = 2 ** 18 / 2
ans = [(x - zero) * step for x in val]
return ans
spi = spidev.SpiDev()
spi.open(0,0)
spi.mode = 1 #polarity: 0 phase: 1
spi.cshigh = True
# ADC Configuration
msg = configuration(1,0,0,0,0,0,0,0)
try:
while True:
spi.writebytes([msg,msg])
time.sleep(0.0027)
ans = spi.xfer([255,255,255,255,255])
#ans = spi.readbytes(5) # optional method. Didn't work either
val = decodeDaisyChain(ans)
print("%6.4fV %6.4fV" % (val[0],val[1]))
time.sleep(0.1)
finally:
spi.close()
