The display count range is one of the digital multimeter characteristics. We know that a DMM is based on an analog/digital converter, and we know that each ADC has a resolution of n bits.
A 16-bits resolution is 2^16 = 65535 steps. log(65536) = 4.8164799306 digits, so something between 50000 and 60000 counts, but we know too that an ADC can't see above its voltage reference (the maximum value that the ADC can convert).
I have two questions:
- The number of steps isn't the same as the number of counts?
- In our example, the number of counts we calculate is 60000. If the reference voltage is 2.5000 V, will the number of counts be 25000?
Update;
At that time I was looking for a handheld digital multimeter of 4.5 digits or higher, the problem was that a lot of them has a low count in the round of 20000, and I knew that it can only be a 16bit ADC or higher, and I wanted to know why it shows only up to 20000 which mean if I measure a 2 volts its ok its gonna show 2.0000v but if I measure 3 Volts I will lose a digit :( it gonna show 03.000v. So I thought at that time it has something to do with the voltage reference and I wanna be sure, that way I can buy a DMM and change it voltage reference I hope I explained my thought better.
