I have a rather weird problem that makes it necessary to sense the four wires off of a bipolar stepper motor(A-,A+,B-,B+) and translate them back into the pins that controlled the stepper motor driver (clk,dir,step).
First i'll outline what I've tried:
- mcp3008 ADC - This guy burned out right away. (I'm assuming because the stepper motor drivers for a nema17 output roughly 1.2amps per coil).
- Looked for higher spec ADCs but I'm somewhat lost.
Questions:
- Is there a better way to do this than using an ADC into a microcontroller?
- What sampling rate would I need to "sense" the stepper motor drivers micro stepping and translate them back/ how to calculate this?
- what ADC resolution would be acceptable/ how to calculate this? ex. 12bit, 16bit...
- What voltage would be "safe" (I know a nema17 is approx 4V, but I'm worried that another stepper will be higher).
- What ADCs are available that meet these spec? (above and below).
- SPI or I2C
- atleast 4 channels or (I can get four 1 channel ADCs).
- through hole component package.
Thank you anyone who responds to all or either of my questions! This is my first post so I hope I was clear enough.
