Following is the Verilog code for a 4-bit unsigned up counter with asynchronous clear as shown in ASIC.CO.IN:
module counter (clk, clr, q);
input clk, clr;
output [3:0] q;
reg [3:0] tmp;
always @(posedge clk or posedge clr)
begin
if (clr)
tmp <= 4’b0000;
else
tmp <= tmp + 1’b1;
end
assign q = tmp;
endmodule
Can I define the output as reg and write the verilog as following?:
input clk, clr;
output [3:0] q;
reg [3:0] q;
begin
if (clr)
q<= 4’b0000;
else
q<= q+ 1’b1;
end
endmodule
As I see this, there is no difference between those two codes, am I wrong?
