Are there any real-life examples for connecting sensors or embedded systems using just two wires that are simultaneously used for both for the energy supply and digital data transmission?
I'm particularly interested in cases in which the sender has to store energy to remain operable (so unlike when using phantom power for microphones, which provide an analog signal anyway).
For instance, the following sketch shows a sender connected to a receiver using a potentially long two-wire connection that is used for both supplying the sender with energy and for data transmission.
The data line is pulled up to 5 V by a pull-up resistor, and the sender can cause a logical 0 to the transmission line by temporarily closing the connection between the two lines. However, it can only send short bursts of data, as it must not deplete its capacitor before the transmission is over. The overall energy consumption of the sender is also quite limited in this way.
