I need to enable a general timer interrupt after generating each pulse in PWM mode. I wrote this program. I will be grateful if you kindly let me know how to enable timer interrupt. This my SPL schematic code:
 void PWMControl(unsigned int Freq){
TIM_TimeBaseInitTypeDef     TimeStructureure;
TIM_OCInitTypeDef       TIMOCStructureure;
        TimeStructure.TIM_Prescaler=Prescale;
        TimeStructure.TIM_CounterMode=TIM_CounterMode_Up;
        TimeStructure.TIM_Period=Period;
        TimeStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TimeStructure.TIM_RepetitionCounter=0;
        TIM_TimeBaseInit(TIM4, &TimeStructure);
        TIM_Cmd(TIM4, ENABLE);
        TIMOCStructure.TIM_OCMode=TIM_OCMode_PWM2;
        TIMOCStructure.TIM_OutputState=TIM_OutputState_Enable;
        TIMOCStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
        TIMOCStructure.TIM_Pulse=Pulse;
        TIM_OC1Init(TIM4, &TIMOCStructure);
        //TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
        TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
According to this post I need to generate N pulse without/ the least CPU workload. (Max Frequency=1MHz)
  • \$\begingroup\$ Do you have a code for the interrupt service routine? \$\endgroup\$
    – Tagli
    Commented Jan 17, 2021 at 19:39
  • \$\begingroup\$ What library are you using? This does not look like the ST HAL drivers. \$\endgroup\$
    – A.R.C.
    Commented Jan 18, 2021 at 8:43
  • \$\begingroup\$ Thank you, I have updated the post content. \$\endgroup\$
    – John Jin
    Commented Jan 19, 2021 at 3:57
  • \$\begingroup\$ I have added the interrupt code but it doesn't work. It just generate a continuous PWM wave form. \$\endgroup\$
    – John Jin
    Commented Jan 20, 2021 at 8:33
  • \$\begingroup\$ 1 MHz is a high frequency for interrupts. You need to use method 3 from the linked question. You need to chain 2 timers, and enable interrupts in the slave timer so that it can stop the master timer. \$\endgroup\$
    – Tagli
    Commented Jan 20, 2021 at 9:29
Are you using CubeMX?
If yes then you have to first enable it in NVIC after configuring TIM4.
Next, inside your logic you have to enable the timer as HAL_TIM_IC_Start_IT(&htim4, TIM_CHANNEL_1);
