I took over a project including PIC18f25k80 microcontrollers and incremental encoders. Basically I just need to follow the position of the motor using the encoder, and drive a device to specific locations. I know that there are more methods to read an encoder and update the position. The motor does not turn fast at all, no high speeds are involved here.
If I were to develop the whole thing from scratch, I probably would hang one channel of the encoder to an interrupt pin on let's say port B, and in the ISR I would check for the state of the other pin. To me, this seems to be the cleanest solution, this method probably catches all position changes, correct me if I am wrong.
Another method would be to poll the 2 channels in the main loop. There is not much in the main loop, basically just adjusting the motor speed and direction based on the position, so at slow speeds, I guess that I would not miss position changes, but it bothers me, that it is still a possibility to miss changes in the encoder channels.
A third option could be to initialize a timer interrupt, and in that interrupt routine, I could check for the pin states. This interrupt could occure twice as fast as a state change would occur at the highest speed, so I guess I would not miss any changes with this method as well.
Now that being said, my question is as follows: which option should I chose?
As I said, I would go with the first one, the encoder channels are attached to RB4 and RB5, so I could just enable the interrupts on port B. But as far as I know, and this is where I am not sure, I can only enable the interrupt for the whole port B on a PIC18f25k80, and not for single pins. That means that all pins on port B would create an interrupt, not just the one I want. And not just the other channel of the encoder, but all of the pins on port B are attached to something, and I cannot change the layout, only the software. Do I see it right, that in this case this method is out, because all pins would cause an interrupt on port B and that would be too much overhead?
And the end of my question: if I see the above problem correctly, which method would you chose, polling of fixed timer interrupts? We are talking about 5 rotations per second tops.
Thanks for the answers in advance!
This is the encoder in question: https://www.power-tronic.com/wp-content/uploads/2019/11/Type-Magnetic-Incremental-2019-01-08.pdf
