In the picture below, I have a power resistor, which is powered either from 12VDC or 24VAC from the rest circuit, as well as another component, which is inserted on the one cable leading to the resistor.
My questions are:
What does each number mean on the power resistor marking?
What could the other component be?
Edit: This is a CCTV camera and the power resistor is used to make sure, through heating, that the glass in front of the lens does not become foggy.
