In verilog, we are supposed to use blocking assignment = in conjunction with always@( * ) to build combinational logic, but what happens if we use non-blocking assignment <= inside of always @* block? For example,
always @ ( * ) begin
   x <= a & b;
   y <= x | c;
end
What is the behavior of this code and what kind of circuit we will end up getting?
According to the example in this slide, we will have y = 1 instead of 0 in the end, because the non blocking assignment uses the old value of x, which is 1, to update y.enter image description here
But according to my experiment, I still get the desired result of y, which is 0. My guess is that, the difference of blocking and non blocking is very subtle when they are used inside of always @* block. The always @* will be triggered again at the line of x<= a & b, so that the next line sees the updated x value. enter image description here
    \$\begingroup\$ Sounds like a great question for a quiz! What do you think will happen? Tell us what you understand about the difference between blocking and non-blocking assignments. \$\endgroup\$ Commented Feb 22, 2021 at 13:59
  • \$\begingroup\$ Been a while since I did verilog. But the concept of non-blocking logic with registers seems to be contrary to the idea of combinatorial logic. If you are using combinatorial logic (on purpose because that is what you want), then I would think you would NOT define x and y to be registers. What would clock them if they are registers? \$\endgroup\$
    – user57037
    Commented Feb 23, 2021 at 1:59
For this particular example, you are right. Both synthesis and simulation yield the same results. However, since you were using non-blocking assignment, the simulator had to enter the always block twice, as an event was triggered by x. This may degrade the simulation performance. This could have been avoided if it was x = a & b ;
This is one of the reasons why using blocking assignment for combinatorial logic has become a coding guideline in Verilog.
Reference: Section 11.0 of this Cummings Paper
