Would you suggest below circuit? Will it work for a long time? What are the advantage and disadvantages of this circuit?
LDR Circuit with TRIAC136 and LDR
https://envirementalb.com/automatic-street-light-circuit/
    \$\begingroup\$ ...real time application For EEs "real time" usually refers to a processor doing things in "real time", meaning doing it immediately. What you mean is "continuous use" or "using it 24/7". The fact that even in cheap (Chinese) commercial products, you will find a slightly more complex (expensive!) circuit means that this circuit is not a good choice. If it was, then for sure those products would use it. \$\endgroup\$ Commented Mar 18, 2021 at 14:24
    \$\begingroup\$ Do people even still use LDRs? Does anyone still make them? Are they even still legal considering the cadmium content? \$\endgroup\$
    – Hearth
    Commented Mar 18, 2021 at 15:21
  • \$\begingroup\$ Unpredictable behavior. May work, may not. \$\endgroup\$
    – user263983
    Commented Mar 18, 2021 at 15:25
  • \$\begingroup\$ @Hearth Yes, they're still made and are available off-the-shelf in countries with more laissez-faire treatment of hazardous substances such as the US and China. I believe the EU's limited exemption on them (for pro audio equipment optocouplers) expired Dec. 31, 2013. \$\endgroup\$ Commented Mar 18, 2021 at 15:29
  • \$\begingroup\$ @SpehroPefhany I haven't seen them in the US in years and years, but perhaps they're still used by hobbyists--I've certainly never used them in anything I designed. \$\endgroup\$
    – Hearth
    Commented Mar 18, 2021 at 15:32
Disadvantages: For one, it won't typically work at all. Typical gate trigger current for the BT136 is 2.5mA/5mA in quadrants I and III respectively.
The 220K resistor will conduct 1.4mA at the very peak of a 220V waveform, insufficient to turn the triac on in either quadrant. At 110V or at cold temperatures or with a particularly numb sample of BT136 things are considerably worse.
Advantages? I guess it conserves energy.
  • \$\begingroup\$ If i use 100K Resistor, will it work ?. it gives 2.3mA. My worries are, is there any possibility to LDR burn out in 230vAC and will it gives proper output? \$\endgroup\$ Commented Mar 18, 2021 at 14:49
  • \$\begingroup\$ Is 2.3mA >> 5mA? I don't think it will damage the LDR, the gate-MTI junctions are across it. It will just sit there consuming a bit of current. \$\endgroup\$ Commented Mar 18, 2021 at 15:23
220k will not work. I used 220 R (ohm) ressistor then worked. Can't beleve. I thought it will burn. But no.Triac is same.
