I admit that I have already made this question in physics SE, but after a month of no answers, I realized engineering might be better suited to everyday applications.
I intend to use (Qi) wireless charging for a project of mine. It uses induction coils to transfer power wirelessly.
In my project, between the coils there will be a 1.5mm (0.04 inch) sheet of brass. The first question I had is if this would work. I tried using a 3mm copper sheet that I have, and sure enough the answer is negative, the sheet absorbs the magnetic field.
But what if I made holes in the sheet? Would some of the field penetrate then? Would it be proportional to the size and "density" of the holes? Or would the conductor still absorb the fields?
