I want to make DIY ATS.
My power supply is from 120Ah 12V battery.
I have a 12V to 220 inverter and a relay circuit.
My problem is the inverter doesn't supply 220V when it is in parallel with the relay circuit.
The inverter is a 12V to 220V pure sine wave transformer.
I'm using an XH-M609 as a relay controller.
The XH-M609 will disconnect the voltage when the battery voltage is low. The relay coil will be on when battery voltage is high, and will off when the battery is low.
Am I doing something wrong?
I think I need to limit the relay input current so inverter can gain more supply.
Can someone help me?
