I am synthesizing a toy application on DE2, but I hit a timing problem (despite every inputs and outputs are clocked in my design). These violations are related to "minimum pulse width"...
How can I avoid such negative slack during FPGA synthesis ?
; Slow Model Minimum Pulse Width: 'CLOCK_27'        ;
; Slack  ; Actual Width ; Required Width ; Type             ; Clock    ; Clock Edge ; Target                     ;
; -0.500 ; 0.500        ; 1.000          ; High Pulse Width ; CLOCK_27 ; Rise       ; HEX0[0]~reg0
    \$\begingroup\$ That relates to a clock - it looks like it's too fast? \$\endgroup\$
    – pjc50
    Commented Jan 28, 2013 at 16:17
  • \$\begingroup\$ No, I don't think so. It is about the shape of Clock_27 \$\endgroup\$
    – JCLL
    Commented Jan 28, 2013 at 16:52
  • \$\begingroup\$ What constraints did you give for the frequency and duty cycle of CLOCK_27? What are the actual frequency and duty cycle you expect in your application? \$\endgroup\$
    – The Photon
    Commented Jan 28, 2013 at 16:54
  • \$\begingroup\$ 27 Mhz is set for frequency. The reports seem to say I can go much higher. Concerning duty cycle, I have 50/50 % and I can change this, if advised. \$\endgroup\$
    – JCLL
    Commented Jan 28, 2013 at 17:23
I think pjc50 has the right idea; have you edited the .sdc file "create_clock" statement? it has a "waveform" keyword that gives a rise and fall time for the clock waveforem, and the above can happen if these are too close together (e.g. "{ 0.000 1.000 }"). Not to belabor the obvious, but it should be more like "{ 0.000 18.519 }" for a 50% duty cycle and a 27 MHz clock.
    \$\begingroup\$ That is the solution. Thx ! \$\endgroup\$
    – JCLL
    Commented Jan 29, 2013 at 8:37
