For a while, I used hand wind transformers to make high voltage (250v, then several stages of cockroft walton to 750-1000v) from ~12-24v at around 10khz and max 100ma on the primary side. But of course it's a lot of work to handwind transformers, and the end result is really far away from a compact design.
I need the high voltage to drive PMTs so it's fortunately very little current.
My goal is to make a transformer that uses max 2W of power, and I think I can get away whit just 1W. Due to this it doesn't matter if the transformer is lossy at a non loaded state, because it uses so little power.
One day, I found small smd transformers on aliexpress what's usually used in flash lamp circuits. It has a 1:25 turn ratio that would be perfect for my needs. But it's usually used in high current applications to charge a capacitor, for a couple of seconds. Because of this the primary has a 8.5 uH inductance which means I need to drive it several MHz if I want below 0.1 amp usage, so it gets impractical pretty fast.
Is there a good way to reduce the primary current in a way that I don't need to drive it that fast. Say drive it at 200kHz max, and add series resistor or inductor, or some current limiting feature. Can that work? Or is it simpler to just go another route, and make say a high voltage boost converter?
