Hello everyone, I am currently trying to find the equivalent impedance of this circuit. The circuit consist of a load C1 which are connected to a two pole pi section with line inductors which are in parallel and at then end is just some sort of measurement block.
Was wondering if finding the equivalent impedance would be as simple calculating the parallel of the two line inductors and then adding in series with the load. After that the resulting impedance would be calculated in parallel with the capacitors from both pi sections.
Is this approach correct or should I do it differently?
