I have a room aka cuboid with 4 x 3 x 2.5meters. In the 3D center is a device under test. To shield against 36kHz electric fiels I have built a faraday cage by sticking 0,012mm thin and 30cm broad aluminium foil at the edges of the cuboid. Overlap on the corners is 15cm.
Resulting attentuation is not so great (4dB).
I want to investigate why, because my aim is 20dB. My faraday cage has several issues:
- My aluminium foil is thinner than skin depth but should be sufficent after this formula (https://physics.stackexchange.com/a/160195/271766) for 70dB
- Overlap is small, but should be sufficent because I sticked it together at some points so it has lots of capacitance (https://electronics.stackexchange.com/a/423112/245958)
- The holes, in fact the entire cuboid faces, are small with respect to wavelength and the device under test is in the middle
I wonder if 1. is the main problem and I need better shielding material or if I should work on 2. and 3.?
