I'm looking at a phase measuring system that uses an amplitude limited version of the received RF signal as a local oscillator to down convert the signal. I've been trying to find a name for this method, along the lines of hetrodyne, homodyne, and autodyne, but none of these seem to fit this configuration.
The input RF is received from multiple elements of a phased array, and one of these elements drives a limiter. (It's assumed that the signal to noise ratio is high enough for this to work.) The limiter output is offset by some fixed frequency and the result is used as a local oscillator to down convert the outputs of each of the antenna elements to the frequency of the offset.
Is there a name for this type of receiver?
