The meaning of the title is, when connecting a DC buck converter and a lithium-ion battery, to ask how to protect the converter from the reverse polarity of the battery
first i will use ideal diode like this answer in this post
So it will cut off the current from the battery
and next things to consider is reverse polarity protection
I was trying to find some circuit examples on the internet and found a similar example circuit with battery charger reverse polarity protection
I just can't use the example circuit because I'm planning a 30V output and equivalent battery series connection or normal load(other circuit or something else)
Another problem is that the second power source is charging the gate of N mosfet, so no power is provided to the load when connecting a resistor to this circuit
I thought about using a optocoupler
what about this circuit
I have simulated the circuit here
optocoupler is activate only when the second supply is connected in reverse polarity
No matter how much I think about it
it too difficult if the electric potential of the two power sources is not separated
it look okay?
I'm worried that the high voltage will destroy the device
and I wonder if there is a better circuit
i need some feedback
thank you for your attention
